361 - Project
sportfury1959
Post by sportfury1959 »
Nighthawk wrote:I have been too, excellent work!
Thanks Bob - enjoy it!
And here come the next pictures:
- As the missing parts are still in the custom office, I keep myself busy with some smaller improvements, for example this professionally welded water neck.
sportfury1959
Well guys, meanwhile you proved yourself as a very tolerant or with a high pain level? :? Nobody complained about my intentions to pain the engine in “Kawasaki Racing Green” – or are you going for the pictures only? However, here we go...
sportfury1959 wrote:Well guys, meanwhile you proved yourself as a very tolerant or with a high pain level? :? Nobody complained about my intentions to pain the engine in “Kawasaki Racing Green” – or are you going for the pictures only? However, here we go...
Nah, we all recognize a prankster, Stefan, even if it isn't April 1st. 8)
However, the Candy Apple Red looks sweet to me...
sportfury1959
- The engine is back
- I chose exactly the same red that I have on the roof …
- … beautiful combination. Do you like it?
sportfury1959
- New front seal for the chain cover
- I simply like this work, smooth, clean, perfect.
sportfury1959
- To prevent oil leak the Dip Stick receives a special glue from M3
- Looks clean …
- … and seals perfect.
Nighthawk
Post by Nighthawk »
To me the "Kawasaki racing green" looked like it was photo shopped on that pic, so we kinda thought you were kidding Stefan.........lol
Bob
savvy59
Post by savvy59 »
Well guys, meanwhile you proved yourself as a very tolerant or with a high pain level? Nobody complained about my intentions to pain the engine in “Kawasaki Racing Green” – or are you going for the pictures only? However, here we go...
Stefan,
I could certainly understand using "Kawasaki Racing Green" especially since it matches the the later 70's Slime Green, Go Lime or whatever color it was called on Mopars. But I can't say it would match your body color combination. :shock:
Keep those pictures rolling in. It is sure great to see someone making progress - you even got Dan motivated! :wink:
Five more months to Carlisle! 8)
sportfury1959
Well guys - seems you all know me too well :) - and here the next bunch of pix
- Let’s see if there is enough clearance between the exhaust manifold and the dip Stick. The dip stick is an aftermarket from Mancini Racing. The hole, where the stick is bolt to the motor mount bracket was not in place, so I had to work on it. :( I hate that!
- I guess I already mentioned the sludge issue a hundred times. The oil passages are clean again and can be closed, hopefully for the next 50 years.
sportfury1959
- Double Roller Timing Chain –
- Final installation and
- correctly lined up
sportfury1959
- Oil Slinger
- Correct torque
sportfury1959
- The push rod for the oil pump was also in the machine shop to rework the contact surfaces with the pump and the cam shaft
- I thought about not installing this rod and go for an electric fuel pump instead
- Maybe I’ll do it late, one day, there are only few bolts to open.
sportfury1959
- The new oil pump drive shaft
- well lubricated
- and lined up, just as the manual requires
sportfury1959
- Fuel Pump
sportfury1959
- and here comes the cover for the timing chain
- probably the last time I see this double roller chain – for the rest of my life
- it starts to look like an engine.
